[GeoNode-users] Replace file document with the same filename got error
Jonathan Doig j.doig at unsw.edu.au
Tue Sep 26 01:07:45 PDT 2017
Hi Donny
Not sure if I understand your question, but the easiest workaround (if you’re admin…) is:
  1.  Geonode > Delete layer
  2.  Ubuntu shell: restart tomcat (requires sudo rights on server)
  3.  Geonode > Upload new layer (same name)
Jonathan
From: Arisandi, Donny (ICRAF) [mailto:D.Arisandi at cgiar.org]
Sent: Tuesday, 26 September 2017 6:02 PM
To: Jonathan Doig <j.doig at unsw.edu.au>; geonode-users at lists.osgeo.org
Subject: RE: [GeoNode-users] Replace file document with the same filename got error
Hi Jonathan, thank you for this info. I managed the error now, but the file created the new file. Is it possible to overwrite the existing file? Because I need the fixed filename to read the data.
Thank you
Donny
Sent: Tuesday, September 26, 2017 2:32 PM
To: Arisandi, Donny (ICRAF); geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi Donny
This is a known issue with layers – I bet it’s the same with documents. It has a fix or at least workaround. Discussed here:
https://github.com/GeoNode/geonode/issues/2932
https://github.com/GeoNode/geonode/issues/2462
Jonathan
From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On Behalf Of Arisandi, Donny (ICRAF)
Sent: Tuesday, 26 September 2017 3:41 PM
To: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: [GeoNode-users] Replace file document with the same filename got error
Hi All,
I have a problem when I tried to replace the file document with the same file name. I got internal server error. Please advise what was the problem.
Thank you
Donny
Sent from my Samsung Galaxy smartphone.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170926/7560a80a/attachment.html>
More information about the geonode-users mailing list
