[GeoNode-users] geoserver error
Vicente deluca.vicente at gmail.com
Thu Sep 28 09:17:23 PDT 2017
Please, look at these error lines. Do not they tell you anything?
Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
at org.geoserver.importer.format.KMLFileFormat. <clinit>
(KMLFileFormat.java:65)
... plus
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No "EPSG:
4326" code from the "European Petroleum Survey Group" authority found for
the "IdentifiedObject" object.
On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com> wrote:
> yes, I have 8GB, memory is not the problem
> Then it must be the kml that I loaded
> I'm ready to make a flush, could this solve it?
> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> They are warnings and I don't think they are causing GeoServer to fail.
>> For sure deleting the default admin GeoNode users won't cause this kind
>> of problem.
>> Are you running GeoServer with enough memory?
>> p
>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
>> wrote:
>>> Sorry, maybe this is off-topic, my question is, Does removes some
>>> projection stuff when I delete the admin (default) user?
>>> The geoserver log error says
>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default workspace
>>> geonode
>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace 'geonode'
>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>>> authority factory: European Petroleum Survey Group
>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>>> Invocation of destroy method failed on bean with name 'importer':
>>> java.lang.NullPointerException
>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>>> initialization failed
>>> org.springframework.beans.factory.BeanCreationException: Error creating
>>> bean with name 'kmlFormat' defined in URL [jar:file:/var/www/geo/httpdoc
>>> s/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2
>>> .7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed;
>>> nested
>>> Another thing I did was add a kml file, but it looked fine!
>>> Some of the two things broke something in the geoserver.
>>> Thank you!
>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>>> wrote:
>>>> Hi,
>>>> the #paver start command throws the following error,
>>>> Error creating bean with name 'kmlFormat' defined in URL
>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>>>> importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation
>>>> of bean failed; nested
>>>> exception is java.lang.ExceptionInInitializerErro
>>>> I think it might have happened after removing some admin users from
>>>> geonode. It's possible?
>>>> I added them again but the problem persists, I do not want to lose the
>>>> information already loaded in the geoserver.
>>>> Thank you!
>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>> Vicente Deluca
>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>> Vicente Deluca
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Vicente Deluca
Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/d5270878/attachment.html>
More information about the geonode-users mailing list
