[GeoNode-users] GeoNode install mix up.
Daniel Victoria daniel.victoria at gmail.com
Tue Apr 3 05:27:06 PDT 2018
Hi all,
First of all, thanks for the great work and this new 2.8 release. Looking
forward to test it out.
Meanwhile, I believe I messed things up on my side. The server that I had
GeoNode 2.6 running went through an update and the new 2.8 version got
installed. I'm now in a package dependency mess and my GeoNode install is
not working.
Looking back now, I thing I should have set the GeoNode 2.6 package on
hold, correct? How can I go back to version 2.6 using apt? Or should the
apt upgrade install version 2.8 on top of 2.6 fine?
Cheers
Daniel
On Tue, Apr 3, 2018 at 9:16 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Thanks all for the release!
> On Tue, Apr 3, 2018 at 2:55 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Thanks a lot Alessio! Great job!
>> 2018-04-03 13:32 GMT+02:00 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>:
>>> *ERRATA CORRIGE:*
>>> * sudo apt-add-repository ppa:geonode/testing -->  sudo
>>> apt-add-repository ppa:geonode/stable*
>>> Regards,
>>> Alessio Fabiani
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> 2018-04-03 13:31 GMT+02:00 Alessio Fabiani <
>>>> Dear all,
>>>> GeoNode release 2.8.0 is out!
>>>> *Installing from apt on Ubuntu 16.04*
>>>> In order to test it through APT, on a clean Ubuntu 16.04 instance run:
>>>> sudo apt update -y
>>>> sudo apt upgrade -y
>>>> sudo apt install geonode
>>>> *Few notes on finalizing the setup (this will be improved on next
>>>> release)*
>>>> *1) Update your default map crs to 3857  sudo nano
>>>> /etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
>>>> DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
>>>> Restart Tomcat in order to allow GeoServer to reload the configuration
>>>> sudo service apache tomcat8 restart*
>>>> *Setting up your custom project*
>>>> Please follow instructions from
>>>> https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
>>>> *Upgrading from 2.6.x release*
>>>> If you would like to update from a 2.6.x development version, please
>>>> take a look at the following document (still not definitive)
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
>>>> *Other type of setup / installer*
>>>> Docker and Windows installers won't be ready by the announcement of the
>>>> official release.
>>>> There are still many issues with those two packages, preventing us to
>>>> publish stable versions of them.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> phone: +39 0584 962313 <0584%20962313>
>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>> mob:   +39 331 6233686 <331%20623%203686>
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180403/50a61276/attachment-0001.html>
More information about the geonode-users mailing list
