[GeoNode-users] Theming Geonode
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Apr 9 13:48:28 PDT 2018
Hi Geonode contributers and developers,
Going back to a previous recommendations made by Tony Schonbuchner and
Alessio Fabiane about Theming Geonode.
 https://github.com/GeoNode/geonode-project
Then the rest should be basic Django.
- create your app
- create your view
- create your template
- create your urls.py
- add it to your settings file
- and add it to project urls.py
http://geonode.org/dev-workshop/#/ *
Adding to Toni details,
once you have been able to setup you geonode-project (see the README on how
to do that), you should be able to add tabs by modifying this file here
https://github.com/GeoNode/geonode-project/blob/2.8.0/projec
t_name/templates/site_base.html
Just remove the {% comment %} / {% endcomment %} keywrods to enable the
code and update the <li> accordingly.
Said that, I did the following based in here
http://geonode.org/dev-workshop/#/3/2 :
 1 - I created a virtualenv <geonode-virtualenv> in
(/etc/julierme_virtualenv/)
 2 - I executed  django-admin.py startproject geonode-project --template=
https://github.com/GeoNode/geonode-project/archive/2.8.0.zip -epy,rst.
 3 - I activated geonode-virtualenv and ran:
               pip install -e geonode-project
Now I have:
1 -  geonode  in ( /etc/geonode/templates and
/usr/local/lib/python2.7/dist-packages/geonode )  #installed via apt-get#
2 -  geonode-project in /etc/julierme_virtualenv/geonode-virtualenv/
#Installed according to here http://geonode.org/dev-workshop/#/3/2#
I got confused in here (http://geonode.org/dev-workshop/#/3/3):
   - cd geonode && paver start_geoserver
   - cd ../my_geonode && python manage.py runserver
*You can wrap this in a simple executable .sh script*
*Should I have two .sh files ( one for cd geonode && paver start_geoserver
and other for cd ../my_geonode && python manage.py runserver) ? if so,
where should them be stored? If one .sh file, where should it be stored?*
*Thank you for your time in advance*
*I appreciated your time and patience.*
*Kind Regards*
*Julierme Pinheiro*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180409/403b4642/attachment.html>
More information about the geonode-users mailing list
