[GeoNode-users] geonode 2.8 updatelayers error
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Apr 16 01:27:37 PDT 2018
Until we don't find resources to refactor apt packaging, apt upgrade would
override everything.
As far as I know the current deb package does not envisage a method to just
upgrade the code. This is something that definitely we should implement.
At this time the only way to update the code-base would be manually.
Nevertheless this is quite easy to achieve, just few commands, from version
2.7 and above.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-04-11 21:05 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> I'm affected by the same issues reported by Andres. The problem is that Iḿ
> using GeoNode to provide WMS to a service that will go online in a couple
> of weeks. So the questions are:
> Will these fixes make it to an apt-package? Or do I need to implement them
> by hand?
> If they make it to a package, will `apt-get update & apt-get upgrade`
> install everything from scratch?
> Cheers
> Daniel
> On Wed, Apr 11, 2018 at 2:47 PM Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Hello,
>> on the maps you can apply this fix here (should be easy)
>> https://github.com/GeoNode/geonode/pull/3732/files
>> If you would like to allow GeoNode storing (and managing) the original
>> bbox/srid, you should consider this one also
>> https://github.com/GeoNode/geonode/pull/3698/files
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-04-11 19:29 GMT+02:00 Andres Juarez <albertoandres.juarez at gmail.com>
>>> Thanks Alessio
>>> This solved the problem in "uploadlayers".
>>> The zoom to the layer extension still shows incorrectly.
>>> Can it be solved in a simple way?
>>> Thank you again!
>>> 2018-04-11 13:10 GMT-03:00 Alessio Fabiani <alessio.fabiani at geo-
>>> solutions.it>:
>>>> Yep,
>>>> this issue has been fixed on master branch (future 2.8.1 version).
>>>> For a quick fix just do
>>>> vim  /usr/local/lib/python2.7/dist-packages/geonode/geoserver/
>>>> helpers.py
>>>> -- go to line  614
>>>> replace
>>>>     "srid": resource.srid
>>>> with
>>>>     "srid": resource.projection
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> 2018-04-11 18:02 GMT+02:00 Andres Juarez <albertoandres.juarez at gmail.
>>>> com>:
>>>>> Hello everyone
>>>>> I just installed stable version 2.8 using APT in Ubuntu 16.04 also
>>>>> newly installed. Geonode works and I can load layers, edit metadata, etc.
>>>>> I have found two problems, perhaps related:
>>>>> 1- When viewing the layer information, the preview takes me to an
>>>>> erroneous extension, however if I look for the location manually the layer
>>>>> looks correct. The same happens when creating a map with any layer.
>>>>> 2- I have connected in geoserver another postgis database and
>>>>> published several layers. When executing "updatelayers" it shows me the
>>>>> following error:
>>>>> Traceback (most recent call last):
>>>>>   File "/usr/bin/django-admin", line 9, in <module>
>>>>>     load_entry_point('Django==1.8.19', 'console_scripts',
>>>>> 'django-admin')()
>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>> line 354, in execute_from_command_line
>>>>>     utility.execute()
>>>>> line 346, in execute
>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>> line 394, in run_from_argv
>>>>>     self.execute(*args, **cmd_options)
>>>>> line 445, in execute
>>>>>     output = self.handle(*args, **options)
>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/
>>>>> geoserver/management/commands/updatelayers.py", line 122, in handle
>>>>>     execute_signals=True)
>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py",
>>>>> line 614, in gs_slurp
>>>>> Exception: ('Failed to process ancho_calle',
>>>>> AttributeError("'FeatureType' object has no attribute 'srid'",))
>>>>> The same happens with the layers loaded by the Geonode interface, it
>>>>> shows the same error.
>>>>> What can I do to solve it?
>>>>> Greetings and thanks in advance.
>>>>>    Andrés Juarez
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>    Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/f339771c/attachment-0001.html>
More information about the geonode-users mailing list
