[GeoNode-users] geoserver-data dir migration (2.10 --> 2.12)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jan 16 04:07:17 PST 2018
I see only part of the catalina log, could you find another one?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-01-16 12:55 GMT+01:00 simone balbo <simone.blb at gmail.com>:
> Hi Alessio,
> I tried to start a GeoServer 2.12.x instance pointing at my "old"
> GeoServer 2.10.x data directory.
> Unfortunately now it seems that the application doesn't start (404 Error
> as a response to a GET to /geoserver).
> Not sure what to do, would you have any suggestion (I attached catalina
> and geoserver log files to this message, in case you have the chance to
> look at it)?
> Best
> Simone
> On 15 January 2018 at 11:49, simone balbo <simone.blb at gmail.com> wrote:
>> Hi Alessio,
>> thanks a lot for the tips.
>> Very good that there's no need to backup/restore the data dir, because I
>> have several TeraBytes of data on that instance...
>> I'll try and see, performing a backup first.
>> Have a nice day
>> Simone
>> On 12 January 2018 at 12:47, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Hi,
>>> if you want just to update GeoServer, there's no need to use backup and
>>> restore. Just replace the WAR, it will update the data dir automatically
>>> (do a copy first anyway).
>>> The only thing that you will need to update manually is the
>>> geofence-server.properties file as specified here
>>> http://geonode.readthedocs.io/en/master/tutorials/admin/geos
>>> erver_geonode_security/index.html#geoserver-2-12-x-and-above
>>> Regards,
>>> Alessio Fabiani
>>> http://goo.gl/it488V for more information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> 2018-01-12 12:35 GMT+01:00 simone balbo <simone.blb at gmail.com>:
>>>> Hi everybody,
>>>> I would like to upgrade the GeoServer of a GeoNode instance in
>>>> production (GeoNode 2.6).
>>>> As regards to the data directory, I would use the Backup/Restore
>>>> functionality in GeoServer. Is this the suggested way forward?
>>>> Did anybody succeed?
>>>> Thanks in advance,
>>>> Simone
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180116/8dd9c386/attachment-0001.html>
More information about the geonode-users mailing list
