[GeoNode-users] SLD upload: "not a valid xml file"
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jun 12 09:46:00 PDT 2018
It should be a defect already fixed on new GeoNode versions. Just tested
SLD with GeoNode master branch and it works fine.
I'd suggest to update the GeoNode code if possible.
Il giorno mar 12 giu 2018 alle ore 18:14 Ariel Neri <ariel.neriw at gmail.com>
ha scritto:
> Hi all. I´m trying to upload sld files made in QGis 2.14 for syling
> layers, but it seems there is something wrong with them.
> I get " The uploaded SLD file is not valid XML "
> Non of the SLD files could be uploaded. I copy the code of a simple one.
> Do i have to modify anything? Thanks.
> (Geonode 2.8 runing on ubunto 16.04 server)
> Ariel
> SLD code:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:ogc="
> http://www.opengis.net/ogc" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" version="1.1.0" xmlns:xlink="
> http://www.w3.org/1999/xlink" xsi:schemaLocation="
> http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd" xmlns:se="
> http://www.opengis.net/se">
>   <NamedLayer>
>     <se:Name>capa_de_prueba</se:Name>
>     <UserStyle>
>       <se:FeatureTypeStyle>
>         <se:Rule>
>           <se:Name>Single symbol</se:Name>
>           <se:PolygonSymbolizer>
>             <se:Fill>
>               <se:SvgParameter name="fill">#e4ea1c</se:SvgParameter>
>             </se:Fill>
>             <se:Stroke>
>               <se:SvgParameter name="stroke">#000001</se:SvgParameter>
>               <se:SvgParameter name="stroke-width">1</se:SvgParameter>
>               <se:SvgParameter
> name="stroke-linejoin">bevel</se:SvgParameter>
>             </se:Stroke>
>           </se:PolygonSymbolizer>
>         </se:Rule>
>       </se:FeatureTypeStyle>
>     </UserStyle>
>   </NamedLayer>
> </StyledLayerDescriptor>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180612/1e33ae8c/attachment.html>
More information about the geonode-users mailing list
