[GeoNode-users] Installed Geonode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jun 14 01:18:52 PDT 2018
Hello,
you should be able to find an Apache installation with a geonode.conf file
similar to this one
https://github.com/GeoNode/geonode-win-installer/blob/master/WinLAMP.4.0.0-developer/WinLAMP.GeoNode/Apache2/conf/geonode.conf
Here you can tweak the HTTPD server configuration.
Il giorno gio 14 giu 2018 alle ore 10:01 Mark Davis <MarkDa at hume.vic.gov.au>
ha scritto:
> Managed to get this installed when using default geonode install path on
> C:/
> Looks like when not using this it was causing issues.
> Any idea which config files need to be changed to go from Localhost to
> server name? Thanks
> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
> Behalf Of *Mark Davis
> *Sent:* Tuesday, 12 June 2018 6:07 PM
> *To:* geonode-users at lists.osgeo.org
> *Subject:* [GeoNode-users] Installed Geonode
> Hi,
> Have installed GeoNode-2.6.x to Windows 2016 standard 64bit.
> I do not seem to be able to load http://localhost/. The page tries to
> load with no response.
> I can access http://localhost:8080/geoserver with no issues, and can log
> in.
> Windows binary install guide does not mention any more details.
> All 3 services seems to be runnings.
> Postgresql
> Apache tomcat
> Apache2
> Have tried adding the environment variables to see if that was the issue
> from looking at the manual install guide, but no change.
> Any suggestions?
> Thanks,
> Md6
> Confidentiality
> This information is Confidential. The information contained within this
> transmission is directed to the defined recipient(s). Should this
> transmission accidentally find its way to an incorrect recipient then it
> should be destroyed immediately without disclosing or using the information
> contained within the transmission. If you have received this transmission
> in error then please inform the sender immediately by return email and
> delete the transmission and all of its associations. Any views expressed in
> this email are those of the individual sender and may not necessarily
> reflect the views of Hume City Council.
> The Hume City Council has implemented anti-virus software, and whilst all
> care is taken, it is the recipient's responsibility to ensure that any
> attachments are scanned for viruses prior to use. The Hume City Council
> monitors its email traffic.
> Confidentiality
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180614/1ee6278f/attachment-0001.html>
More information about the geonode-users mailing list
