[GeoNode-users] Embed Download layer facility in Geonode Map Client
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jun 21 01:17:34 PDT 2018
Hello Joshi,
currently the Javascript configuration initializing the GIS client for the
embedded map, is done through this template
https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_embed.html#L14
You can either try to tweak the "GeoNode.Viewer" configuration by adding
more components, or use the "GeoNode.Composer" instead like for the Map
Edit page
https://github.com/GeoNode/geonode/blob/master/geonode/client/templates/geoext/maps/map_geoexplorer.js
Il giorno mer 20 giu 2018 alle ore 16:08 Joshi, Jigeeshu <
Jigeeshu.Joshi at ils-forschung.de> ha scritto:
> Hi,
> We are using Geonode 2.8 at our organization. We uploaded data/ layers and
> we would like to publish map and embed the URL in our organization web page
> to make it available to our clients. However, I find that the embed URL
> does not have provision to download layers (for these layers download
> permission is set to Anyone) in the map and query the layers.  It only
> allows to identity the feature on the map as an attribute pop up table. How
> could I add query tool and download layer tool in this map client.  Has
> anyone tried it and could guide me ?
> Thanks in advance !
> Joshi
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180621/1e489584/attachment.html>
More information about the geonode-users mailing list
