[GeoNode-users] [GeoNode-devel] GeoNode 2.8.0 release candidate artifacts ready for testing
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Mar 30 10:35:03 PDT 2018
Thanks Alessio,
I will pick up an action item to test against geonode-project template
(master?) and update the ansible scripts for this release.
Cheers,
Angelos
On Fri, Mar 30, 2018 at 6:54 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Thanks a lot Alessio! Great work. I’ll test it ASAP a and give a feedback.
> Buona Pasqua!
> Il giorno ven 30 mar 2018 alle 15:42 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> ha scritto:
>> Dear all,
>> before pushing the final 2.8.0 release, please give a try to the release
>> candidate packages.
>> In order to test it through APT, on a *clean* Ubuntu *16.04* instance
>> run:
>> sudo apt-add-repository *ppa:geonode/testing*
>> sudo apt update -y
>> sudo apt upgrade -y
>> sudo apt install geonode
>> If you would like to update from a 2.6.x development version, please take
>> a look at the following document (still not definitive)
>> http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_update/26_to_27/index.html#update-from-
>> geonode-2-6-3-to-geonode-2-7
>> Docker and Windows installer won't be ready by the announcement of the
>> official release. There are still many issues with those two packages,
>> preventing us to publish stable versions of them.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180330/0fe05d7e/attachment.html>
More information about the geonode-users mailing list
