[GeoNode-users] Preferred installation for production
Annalisa Schiavon annalisa.schiavon at gmail.com
Wed May 16 00:05:27 PDT 2018
Hi Alessio!
Thank you for the reply!  Now It's more clear to me!
Annalisa
2018-05-15 11:20 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Hello Annalisa,
> recently the preferred way is to use Docker Compose method.
> The setup through ppa can also work but there are currently a couple of
> things to be aware of:
> 1. It will install the stable release not the most updated. That means
> that recent fixes won't be included there
> 2. Currently the debian package is not able to just "update" the GeoNode
> packages. It always needs to be installed on a clean Ubuntu machine.
> For the reasons above, I would proceed with this method
> http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/index.html
> and of course, when everything has been setup, change the default
> passwords and put DEBUG = False on settings.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-05-14 11:32 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Hi all,
>> we have a working geonode 2.4 in production on ubuntu 16.04. Now we want
>> to move to 2.8. What is the  preferred  installation method ? New server
>> (always ubuntu 16.04) will going to replace current server.
>> The* old *geonode was installed via apt-get :
>> sudo add-apt-repository ppa:geonode/stable
>> sudo apt-get update
>> sudo apt-get install geonode
>> Then I had installed geonode-project for a few changes in logos, colors
>> and so on:
>> django-admin startproject geoportale20 --template=https://github.com/
>> GeoNode/geonode-project/archive/master.zip -epy,rst
>> sudo pip install -e geoportale20
>> Now I can install 2.8 version on a clean ubuntu 16.04 with :
>> sudo apt-add-repository ppa:geonode/stable
>> sudo apt update -y
>> sudo apt upgrade -y
>> sudo apt install geonode
>> How do you suggest to install geonode-project ?
>> I've read of  virtualenv  but I don't have experience on it and I need
>> geonode for production!
>> Thanks,
>> Annalisa
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180516/6e388b36/attachment.html>
More information about the geonode-users mailing list
