[GeoNode-users] Preferred installation for production
Stefan Steiniger sstein at geo.uzh.ch
Tue May 15 05:58:27 PDT 2018
Hi Alessio,
thanks for pointing that out! (we will also install a new version
anytime soon - switching from 2.0)
cheers,
Stefan
On 5/15/18 06:20, Alessio Fabiani wrote:
> Hello Annalisa,
> recently the preferred way is to use Docker Compose method.
> The setup through ppa can also work but there are currently a couple
> of things to be aware of:
> 1. It will install the stable release not the most updated. That means
> that recent fixes won't be included there
> 2. Currently the debian package is not able to just "update" the
> GeoNode packages. It always needs to be installed on a clean Ubuntu
> machine.
> For the reasons above, I would proceed with this method
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> and of course, when everything has been setup, change the default
> passwords and put DEBUG = False on settings.
> Regards,
> Alessio Fabiani
> ==GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.==Ing. Alessio Fabiani
> @alfa7691Founder/Technical Lead
> GeoSolutions S.A.S.Via di Montramito 3/A55054  Massarosa
> (LU)Italyphone: +39 0584 962313fax:     +39 0584 1660272mob:   +39 331
> 6233686http://www.geo-solutions.ithttp://twitter.com/geosolutions_it-------------------------------------------------------
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> cortesemente di darcene notizia via e-mail e di procedere alla
> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse, costituisce comportamento contrario ai principi dettati dal
> D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data Protection Code).Any use not in accord with its purpose, any
> disclosure, reproduction, copying, distribution, or either
> dissemination, either whole or partial, is strictly forbidden except
> previous formal approval of the named addressee(s). If you are not the
> intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message
> that has been received in error. The sender does not give any warranty
> or accept liability as the content, accuracy or completeness of sent
> messages and accepts no responsibility  for changes made after they
> were sent or for other risks which arise as a result of e-mail
> transmission, viruses, etc.
> 2018-05-14 11:32 GMT+02:00 Annalisa Schiavon
> <annalisa.schiavon at gmail.com <mailto:annalisa.schiavon at gmail.com>>:
>     Hi all,
>     we have a working geonode 2.4 in production on ubuntu 16.04. Now
>     we want to move to 2.8. What is the preferredinstallation method ?
>     New server (always ubuntu 16.04) will going to replace current server.
>     The*old *geonode was installed via apt-get :
>     sudo add-apt-repository ppa:geonode/stable
>     sudo apt-get update
>     sudo apt-get install geonode
>     Then I had installed geonode-project for a few changes in logos,
>     colors and so on:
>     django-admin startproject geoportale20
>     --template=https://github.com/GeoNode/geonode-project/archive/master.zip
>     <https://github.com/GeoNode/geonode-project/archive/master.zip>
>     -epy,rst
>     sudo pip install -e geoportale20
>     Now I can install 2.8 version on a clean ubuntu 16.04 with :
>     sudo apt-add-repository ppa:geonode/stable
>     sudo apt update -y
>     sudo apt upgrade -y
>     sudo apt install geonode
>     How do you suggest to install geonode-project ?
>     I've read of virtualenvbut I don't have experience on it and I
>     need geonode for production!
>     Thanks,
>     Annalisa
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/geonode-users
>     <https://lists.osgeo.org/mailman/listinfo/geonode-users>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/5cc6fbe7/attachment-0001.html>
More information about the geonode-users mailing list
