[GeoNode-users] Geonode-Project: Apache Config / geonode.conf
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu May 17 11:33:02 PDT 2018
making a correction in my previous e-mail.
I can see the changes done through geonode-dev css and site_base.html and
site_index.html over the geonode-production, But geonode-production uses
geonode-dev database within this python-path config.
Kind regards
Julierme
2018-05-17 15:30 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> 2018-05-17 15:30 GMT-03:00 Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com>:
>> Hi Francesco,
>> Thank you for your questions. I added tabs and text change to geonode-dev
>> (geonode-dev.png) and I can see the changes over geonode-production
>> (geonode-production.png). However If I keep WSGIDaemonProcess my_geonode
>> python-path=/home/my_geonode/my_geonode:/home/geo/Envs/my_ge
>> onode/lib/python2.7/site-packages user=www-data threads=15 processes=2
>> geonode-dev within this python-path config.
>> However if I keep WSGIDaemonProcess geonode python-path=/home/geonode/my_g
>> eonode:/home/geo/Envs/geonode/lib/python2.7/site-packages user=www-data
>> I can see the changes done through geonode-dev css and not the changes in
>> site_base.html and site_index.html. But geonode-productions is using its
>> right database.
>> Could you give a clue in what is going on? I also following the
>> directions in here http://geonode.org/dev-workshop/#/8/3.
>> Thank you for your time in advance
>> Julierme
>> 2018-05-17 13:16 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Once you have installed GeoNode as a library/package in your my_geonode
>>> virtual environment did you see your custom text and tabs changes starting
>>> the development server? That means “python manage.py run server” ?
>>> Once you’ll get this achievement then the apache configuration will be
>>> easier.
>>> Hope this helps
>>> Francesco
>>> Il giorno 17/mag/2018, alle ore 18:01, Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Dear Framcesco,
>>> Thank you very much for your reply. I have gone through
>>> http://geonode.org/dev-workshop/#/ several times. It is a great source,
>>> but again this issue was related to geonode.conf /apache2 config.
>>> I got to fix this problem making changes to geonode.conf. In my case, if
>>> I have geonode production in /home/geonode and geonode-project in
>>> /home/my_geonode, the geonode.conf must have all information related to
>>> geonode-project, and I was still gathering information from
>>> geonode-production in geonode.conf.
>>> I appreciated your time and help.
>>> Kind regards
>>> Julierme
>>> 2018-05-17 12:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Dear Julierme,
>>>> I encourage you to follow scrupulously the developer workshop where
>>>> everything you are trying to do is well covered http://geonode.org/dev
>>>> -workshop/#/.
>>>> Francesco
>>>> Il giorno 17/mag/2018, alle ore 17:06, Julierme Pinheiro <
>>>> Dear all geonode developers,
>>>> I have made changes in my geonode production through geonode-project.
>>>> Just now, I realized that the geonode-project css config is being applied
>>>> to geonode production main page, however my new tabs and text change in
>>>> site_base.html and site.index.html are not being applied to geonode
>>>> production main page.
>>>> I ran the commands python manage.py migrate and python manage.py
>>>> collectstatic and realized that static_root was created in
>>>> /home/my_geonode/my_geonode/my_geoonde/static_root
>>>> geonode.conf Directories make reference to several paths
>>>> /home/my_geonode/my_geonode/my_geonode/uploaded/ and
>>>> /home/my_geonode/my_geonode/my_geonode/uploaded/* (group,
>>>> people_group, documents, Layers, avatars and thumbs)
>>>> but directory uploaded is no in /home/my_geonode/my_geonode/my_geoonode
>>>> I wonder if this directory <uploaded> and its subdirectories <group,
>>>> people_group, documents, Layers, avatars and thumbs> are added manually.
>>>> In order to see the new tabs and text changes in geonode production, I
>>>> also added another directory to geonode.conf
>>>>  <Directory "/home/my_geonode/my_geonode/my_geonode/templates/">
>>>>         Order allow,deny
>>>>         Options Indexes FollowSymLinks
>>>>         Allow from all
>>>>         Require all granted
>>>>         IndexOptions FancyIndexing
>>>>  </Directory>
>>>> The directory templates contains site_base.html and site_index.html.
>>>> But yet I could not see the new tabs in my geonode production main page.
>>>> Any help on that will be very appreciated.
>>>> Kind regards
>>>> Julierme
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/f87925a8/attachment.html>
More information about the geonode-users mailing list
