[GeoNode-users] how to make multiple overlay name (Handy Rusydi)
Toni Schönbuchner toni.schoenbuchner at csgis.de
Wed Nov 21 08:19:00 PST 2018
Great info! Thanks Paolo!
– cheers, Toni
> Am 21.11.2018 um 17:16 schrieb Paolo Corti <pcorti at gmail.com>:
> Hi Toni and Handy
> the WorldMap client implements this (and many other things, most
> notably a layer graduated style editor and a gazetteer:
> https://github.com/GeoNode/geonode/issues/3718).
> You can look at a working map using this client here (in this case we
> are still using old GeoNode): http://worldmap.harvard.edu/boston/
> Handy, feel free to register to it and create some test map in our
> WorldMap live instance to see if that is what you are looking for. In
> which case you may want to use the worldmap-client, I added some
> instructions here (which at this point may be a bit old and require
> and update): http://docs.geonode.org/en/master/reference/worldmap.html
> Keep in mind that this requires PostGIS as a backend for now. Also, it
> works well only in latest master (GeoNode 2.10). It is possible to
> avoid the hypermap thing by setting the USE_HYPERMAP setting to False.
> Hope this helps
> best
> Paolo
> On Wed, Nov 21, 2018 at 5:19 AM Toni Schönbuchner
> <toni.schoenbuchner at csgis.de> wrote:
>> Hi Handy,
>> I´ve thought again about your request. I more or less sure that other viewers
>> have not implemented this feature as well. To sort or group your layers in a map
>> the grouping information has to be saved somewhere in the DB. Looking at the models
>> I cannot spot some field to store this information. (Devs please correct me if I´m wrong).
>> I think what´s currentlky happening is that the tree is build from a request against the api:
>> f.e.: http://master.demo.geonode.org/api/layers
>> So if you need this feature a new github issue should be the the best choice.
>> cheers,
>> Toni
>> Am 20.11.2018 um 23:54 schrieb Handy Rusydi <handy at galerigis.com>:
>> Thanks Toni for your reply,
>> I have upload my expected looks in layer preview. In untitled.png is my expected result.
>> Regards
>> Handy
>> <Untitled1.png><Untitled.png>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
More information about the geonode-users mailing list
