[GeoNode-users] Customize the Categories on a Genode 2.8 installation
Toni Schönbuchner toni.schoenbuchner at csgis.de
Wed Mar 27 23:07:18 PDT 2019
Dear Yewondwossen,
welcome on board. Yes your message was delivered:
https://lists.osgeo.org/pipermail/geonode-users/2019-March/005449.html <https://lists.osgeo.org/pipermail/geonode-users/2019-March/005449.html>
Have you seen that there is a setting regarding customizations which is by defaul false.
http://docs.geonode.org/en/master/reference/developers/settings.html#modify-topiccategory <http://docs.geonode.org/en/master/reference/developers/settings.html#modify-topiccategory>
A word of caution, the quick installation is outdated / currently unmaintained.
If it´s not to late I would suggest doing a manual install or use the docker stack.
Cheers,
Toni
> Am 28.03.2019 um 06:56 schrieb Yewondwossen Assefa <assefay at gmail.com>:
> Dear all,
> I had re-registered to the geonode users mailing list and sent an email yesterday. Not sure if it has reached the community. I also did not see the email in the March archive. Has it reached you or is any approval process needed?
> Many thanks,
> Y. Assefa
> ---------- Forwarded message ---------
> From: Yewondwossen Assefa <assefay at gmail.com <mailto:assefay at gmail.com>>
> Date: Wed, Mar 27, 2019 at 6:37 PM
> Subject: Customize the Categories on a Genode 2.8 installation
> To: <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
> Dear all,
> Is there a way to customize the categories available in Geonode (list of "available data sets" seen on the first page)?
> I tried to use the admin interface to  "Add topic category" and also disable some categories (Is choice un-selected) but did not see any changes.
> As a quick workaround, should changes be made directly on some of the installed files (index.html)
> Installation was done using the quick install guide.
> Thanks
> regards,
> Y. Assefa
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190328/3f633289/attachment.html>
More information about the geonode-users mailing list
