[GeoNode-users] GEONODE Bad Request or Bad Gateway
Ariel Cabezas gerardoarielc at gmail.com
Mon Dec 21 03:45:39 PST 2020
Well, I found the problem, it was my error, I missed setting the variable
GEONODE_LB_HOST_IP = IP-public, in the .env file
I leave the solution here in case it is useful to other users
Cheers
El vie, 18 dic 2020 a las 11:36, Ariel Cabezas (<gerardoarielc at gmail.com>)
escribió:
> Good morning / afternoon everyone
> I did the Geonode installation with the instructions on the website
> https://docs.geonode.org/en/master/install/basic/index.html
> My problem is the following:
> I was assigned a virtual machine with enablement of ports 8062 for web and
> the SSH port. Ubuntu Server 18. The IP is in this format Public-IP: 8062
> I did the installation remotely through SSH.
> I can access geoserver, it is correct, I can navigate upload data and
> preview http:// public-IP:8062/geoserver/
> The problem is the Geonode that I cannot access the url (http: //
> public-IP:8062 /) it returns BAD REQUEST (400) or (502) BAD GATEWAY
> Modify the .env file, (for each change I run docker-compose up -d), but I
> don't know if what I did is right, or maybe I need to modify elsewhere.
> The modifications I made to the .env file (without success) were:
> SITEURL = http: // public-IP: 8062 /
> HTTP_HOST = IP-public
> HTTPS_HOST =
> HTTP_PORT = 8062
> I already appreciate your help
> Ariel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201221/48de7daf/attachment.html>
More information about the geonode-users mailing list
