[GeoNode-users] Raster series as temporal layer
Simone Giannecchini simone.giannecchini at geo-solutions.it
Wed Jan 20 10:28:16 PST 2021
Hi Alexander,
I think this is more of a GeoServer related question.
If you can set up an ImageMosaic in GeoServer then you can use the
updateLayers management command and have this layer become a GeoNode layer.
Obviously the work is a little more complicated than that, I was just
trying to give you some directions.
There are quite a number of documents around for setting up a raster time
series in GeoServer...
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com> wrote:
> I have the same question--Is it possible to expose the Time dimension for a
> raster layer in Geonode?
> The layer is updated daily, so the time dimension changes.
> Kind regards,
> Alex
> Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210120/07317d94/attachment.html>
More information about the geonode-users mailing list
