[GeoNode-users] Raster series as temporal layer
Alexander Petkov greenkov at gmail.com
Thu Jan 21 01:12:46 PST 2021
Hello Simone and Geonode users:
I have configured the Mosaic in Geoserver with Time dimension enabled, and
ran the updatelayers command.
The layer is recognised and listed in Geonode.
Now I am wondering if it is possible to expose the temporal extent  as
well, in the metadata viewable in Geonode.
Thank you in advance with any pointers,
Alex
On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Hi Alexander,
> I think this is more of a GeoServer related question.
> If you can set up an ImageMosaic in GeoServer then you can use the
> updateLayers management command and have this layer become a GeoNode layer.
> Obviously the work is a little more complicated than that, I was just
> trying to give you some directions.
> There are quite a number of documents around for setting up a raster time
> series in GeoServer...
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
> wrote:
>> I have the same question--Is it possible to expose the Time dimension for
>> a
>> raster layer in Geonode?
>> The layer is updated daily, so the time dimension changes.
>> Kind regards,
>> Alex
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210121/d1e7a02c/attachment.html>
More information about the geonode-users mailing list
