[GeoNode-users] Geonode Rest Role Service
Kabatha Patrick kpparto at gmail.com
Wed Nov 8 09:07:29 PST 2023
I reinstalled the geoserver and made a connection to the geonode postgis
database (geonode_data). Republished all the data in geoserver and ran the
geonode "./manage_local.sh update layers" to sync the layers in geonode
with the current geoserver.
I may also need to run this command to update your URL's ./manage_local.sh
migrate_baseurl --source-address=http://localhost:8080/geoserver
--target-address=http://domainname/geoserver
Hope it works for you.
Cheers!
On Tue, Oct 31, 2023 at 12:14 PM Kabatha Patrick <kpparto at gmail.com> wrote:
> Hi Jose,
> Unfortunately, I didn't get a workaround on this.
> I may be forced to reinstall the geoserver all together and see if it
> helps.
> Cheers!
> On Sun, Oct 29, 2023 at 3:38 AM Jose Cáceres <jose.atyus at gmail.com> wrote:
>> Hi,
>> I'm having the same situation on a 3.3.4 version.
>> Where you able to find a solution?
>> Thanks,
>> José
>> [image: Mailtrack]
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality11&> Sender
>> notified by
>> Mailtrack
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality11&> 28/10/23,
>> 18:37:28
>> On Fri, Oct 27, 2023 at 7:08 AM Kabatha Patrick via geonode-users <
>> geonode-users at lists.osgeo.org> wrote:
>>> Hi,
>>> Why would the Geoserver - Geonode rest role service list be empty? Even
>>> after correct configurations of the authentication/global settings.
>>> [image: image.png]
>>> Or do I have to reinstall my geoserver instance.
>>> Thanks,
>>> GIS Analyst
>>> Geography & Ecology.
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> José David Cáceres
>> Ingeniero Ambiental
>> Máster en Tecnologías de la Información Geográfica
>> e-mail: jose.atyus at gmail.com
> GIS Analyst
GIS Analyst
Ecologist
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231108/a53e88b2/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231108/a53e88b2/attachment-0001.png>
More information about the geonode-users mailing list
