[GeoNode-users] linked_resources API always return 404
Alexandre Gacon alexandre.gacon at gmail.com
Tue Oct 10 08:54:10 PDT 2023
Hi Giovanni,
Thanks for the reply. I had a look at the docker compose file for the
version so probably this is not the good place to get it.
What do you suggest to retrieve the correct version?
Regards
Alexandre
Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> a écrit :
> This endpoint has been available since version 4.1.0
> <https://github.com/GeoNode/geonode/pull/10941>.
> Giovanni
> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
> geonode-users at lists.osgeo.org> wrote:
>> Hello,
>> For a few weeks now, our geonode instance always returns a 404 error when
>> we try to use the linked_resources endpoint of the API.
>> As a result:
>> - The map preview in the right side of a dataset is never displayed with
>> an ever lasting loader
>> - When we try to create a new map, we also have an ever lasting loader,
>> we never get to display the default basemap
>> - Existing maps are displayed correctly
>> The problem happens with either layers in database or with new layer
>> uploaded with shapefile.
>> GeoNode version : 4.0
>> GeoServer version : 2.20.6
>> Do you have any idea on what's going on?
>> Alexandre Gacon
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> cell:     +39 345 2815774
> fax:      +39 0584 1660272
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231010/b1646c7e/attachment-0001.htm>
More information about the geonode-users mailing list
