[GeoNode-users] linked_resources API always return 404
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Tue Oct 10 08:58:33 PDT 2023
Paste here the content of the src/requirements.txt file.
Giovanni
On Tue, Oct 10, 2023 at 5:54 PM Alexandre Gacon <alexandre.gacon at gmail.com>
wrote:
> Hi Giovanni,
> Thanks for the reply. I had a look at the docker compose file for the
> version so probably this is not the good place to get it.
> What do you suggest to retrieve the correct version?
> Regards
> Alexandre
> Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
> giovanni.allegri at geosolutionsgroup.com> a écrit :
>> This endpoint has been available since version 4.1.0
>> <https://github.com/GeoNode/geonode/pull/10941>.
>> Giovanni
>> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
>> geonode-users at lists.osgeo.org> wrote:
>>> Hello,
>>> For a few weeks now, our geonode instance always returns a 404 error
>>> when we try to use the linked_resources endpoint of the API.
>>> As a result:
>>> - The map preview in the right side of a dataset is never displayed with
>>> an ever lasting loader
>>> - When we try to create a new map, we also have an ever lasting loader,
>>> we never get to display the default basemap
>>> - Existing maps are displayed correctly
>>> The problem happens with either layers in database or with new layer
>>> uploaded with shapefile.
>>> GeoNode version : 4.0
>>> GeoServer version : 2.20.6
>>> Do you have any idea on what's going on?
>>> Alexandre Gacon
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Dott. Giovanni Allegri
>> Technical Lead / Project Manager
>> GeoSolutions Group
>> phone: +39 0584 962313
>> cell:     +39 345 2815774
>> fax:      +39 0584 1660272
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231010/2fe9aafc/attachment.htm>
More information about the geonode-users mailing list
