[GeoNode-users] linked_resources API always return 404
Alexandre Gacon alexandre.gacon at gmail.com
Tue Oct 10 08:59:22 PDT 2023
I will get it as soon as possible.
Le mar. 10 oct. 2023 à 17:58, Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> a écrit :
> Paste here the content of the src/requirements.txt file.
> Giovanni
> On Tue, Oct 10, 2023 at 5:54 PM Alexandre Gacon <alexandre.gacon at gmail.com>
> wrote:
>> Hi Giovanni,
>> Thanks for the reply. I had a look at the docker compose file for the
>> version so probably this is not the good place to get it.
>> What do you suggest to retrieve the correct version?
>> Regards
>> Alexandre
>> Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
>>> This endpoint has been available since version 4.1.0
>>> <https://github.com/GeoNode/geonode/pull/10941>.
>>> Giovanni
>>> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
>>> geonode-users at lists.osgeo.org> wrote:
>>>> Hello,
>>>> For a few weeks now, our geonode instance always returns a 404 error
>>>> when we try to use the linked_resources endpoint of the API.
>>>> As a result:
>>>> - The map preview in the right side of a dataset is never displayed
>>>> with an ever lasting loader
>>>> - When we try to create a new map, we also have an ever lasting loader,
>>>> we never get to display the default basemap
>>>> - Existing maps are displayed correctly
>>>> The problem happens with either layers in database or with new layer
>>>> uploaded with shapefile.
>>>> GeoNode version : 4.0
>>>> GeoServer version : 2.20.6
>>>> Do you have any idea on what's going on?
>>>> Alexandre Gacon
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts!
>>> Visit http://bit.ly/gs-services-us for more information.
>>> Dott. Giovanni Allegri
>>> Technical Lead / Project Manager
>>> GeoSolutions Group
>>> phone: +39 0584 962313
>>> cell:     +39 345 2815774
>>> fax:      +39 0584 1660272
>>> https://www.geosolutionsgroup.com/
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> GeoSolutions Group
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231010/6c2c9872/attachment-0001.htm>
More information about the geonode-users mailing list
