[GeoNode-users] linked_resources API always return 404
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Wed Oct 11 03:13:22 PDT 2023
Are you running a vanilla GeoNode (i.e. not a GeoNode Project)?
Can you share the content of the file geonode/__init__.py? It contains the
__version__ variable.
Otherwise you con obtain it from the browser:
https://yourgeonode.com/version.txt (example
<https://development.demo.geonode.org/version.txt>).
Giovanni
On Wed, Oct 11, 2023 at 10:13 AM Alexandre Gacon <alexandre.gacon at gmail.com>
wrote:
> Hello,
> The requirements file which is embedded in the docker image.
> Le mar. 10 oct. 2023 à 17:59, Alexandre Gacon <alexandre.gacon at gmail.com>
> a écrit :
>> I will get it as soon as possible.
>> Le mar. 10 oct. 2023 à 17:58, Giovanni Allegri <
>> giovanni.allegri at geosolutionsgroup.com> a écrit :
>>> Paste here the content of the src/requirements.txt file.
>>> Giovanni
>>> On Tue, Oct 10, 2023 at 5:54 PM Alexandre Gacon <
>>> alexandre.gacon at gmail.com> wrote:
>>>> Hi Giovanni,
>>>> Thanks for the reply. I had a look at the docker compose file for the
>>>> version so probably this is not the good place to get it.
>>>> What do you suggest to retrieve the correct version?
>>>> Regards
>>>> Alexandre
>>>> Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
>>>>> This endpoint has been available since version 4.1.0
>>>>> <https://github.com/GeoNode/geonode/pull/10941>.
>>>>> Giovanni
>>>>> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
>>>>> geonode-users at lists.osgeo.org> wrote:
>>>>>> Hello,
>>>>>> For a few weeks now, our geonode instance always returns a 404 error
>>>>>> when we try to use the linked_resources endpoint of the API.
>>>>>> As a result:
>>>>>> - The map preview in the right side of a dataset is never displayed
>>>>>> with an ever lasting loader
>>>>>> - When we try to create a new map, we also have an ever lasting
>>>>>> loader, we never get to display the default basemap
>>>>>> - Existing maps are displayed correctly
>>>>>> The problem happens with either layers in database or with new layer
>>>>>> uploaded with shapefile.
>>>>>> GeoNode version : 4.0
>>>>>> GeoServer version : 2.20.6
>>>>>> Do you have any idea on what's going on?
>>>>>> Alexandre Gacon
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> GeoServer Professional Services from the experts!
>>>>> Visit http://bit.ly/gs-services-us for more information.
>>>>> Dott. Giovanni Allegri
>>>>> Technical Lead / Project Manager
>>>>> GeoSolutions Group
>>>>> phone: +39 0584 962313
>>>>> cell:     +39 345 2815774
>>>>> fax:      +39 0584 1660272
>>>>> https://www.geosolutionsgroup.com/
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> GeoSolutions Group
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> Alexandre Gacon
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231011/592029b7/attachment-0001.htm>
More information about the geonode-users mailing list
