[GeoNode-users] linked_resources API always return 404
Alexandre Gacon alexandre.gacon at gmail.com
Wed Oct 11 06:18:18 PDT 2023
Yes the customer uses a vanilla GeoNode.
The version returned by the browser is  : 4.1.0.dev0.
Le mer. 11 oct. 2023 à 12:13, Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> a écrit :
> Are you running a vanilla GeoNode (i.e. not a GeoNode Project)?
> Can you share the content of the file geonode/__init__.py? It contains
> the  __version__ variable.
> Otherwise you con obtain it from the browser:
> https://yourgeonode.com/version.txt (example
> <https://development.demo.geonode.org/version.txt>).
> Giovanni
> On Wed, Oct 11, 2023 at 10:13 AM Alexandre Gacon <
> alexandre.gacon at gmail.com> wrote:
>> Hello,
>> The requirements file which is embedded in the docker image.
>> Le mar. 10 oct. 2023 à 17:59, Alexandre Gacon <alexandre.gacon at gmail.com>
>> a écrit :
>>> I will get it as soon as possible.
>>> Le mar. 10 oct. 2023 à 17:58, Giovanni Allegri <
>>>> Paste here the content of the src/requirements.txt file.
>>>> Giovanni
>>>> On Tue, Oct 10, 2023 at 5:54 PM Alexandre Gacon <
>>>>> Hi Giovanni,
>>>>> Thanks for the reply. I had a look at the docker compose file for the
>>>>> version so probably this is not the good place to get it.
>>>>> What do you suggest to retrieve the correct version?
>>>>> Regards
>>>>> Alexandre
>>>>> Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
>>>>>> This endpoint has been available since version 4.1.0
>>>>>> <https://github.com/GeoNode/geonode/pull/10941>.
>>>>>> Giovanni
>>>>>> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
>>>>>> geonode-users at lists.osgeo.org> wrote:
>>>>>>> Hello,
>>>>>>> For a few weeks now, our geonode instance always returns a 404 error
>>>>>>> when we try to use the linked_resources endpoint of the API.
>>>>>>> As a result:
>>>>>>> - The map preview in the right side of a dataset is never displayed
>>>>>>> with an ever lasting loader
>>>>>>> - When we try to create a new map, we also have an ever lasting
>>>>>>> loader, we never get to display the default basemap
>>>>>>> - Existing maps are displayed correctly
>>>>>>> The problem happens with either layers in database or with new layer
>>>>>>> uploaded with shapefile.
>>>>>>> GeoNode version : 4.0
>>>>>>> GeoServer version : 2.20.6
>>>>>>> Do you have any idea on what's going on?
>>>>>>> Alexandre Gacon
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> GeoServer Professional Services from the experts!
>>>>>> Visit http://bit.ly/gs-services-us for more information.
>>>>>> Dott. Giovanni Allegri
>>>>>> Technical Lead / Project Manager
>>>>>> GeoSolutions Group
>>>>>> phone: +39 0584 962313
>>>>>> cell:     +39 345 2815774
>>>>>> fax:      +39 0584 1660272
>>>>>> https://www.geosolutionsgroup.com/
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> GeoSolutions Group
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> Alexandre Gacon
> GeoSolutions Group
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231011/9fa3f0c5/attachment-0001.htm>
More information about the geonode-users mailing list
