[GeoNode-users] linked_resources API always return 404
Alexandre Gacon alexandre.gacon at gmail.com
Thu Oct 12 07:53:15 PDT 2023
Is it possible that during a build of their code they retrieved a geonode
mapstore client version not compatible with their backend?
Regards
Alexandre
Le mer. 11 oct. 2023 à 15:18, Alexandre Gacon <alexandre.gacon at gmail.com> a
écrit :
> Yes the customer uses a vanilla GeoNode.
> The version returned by the browser is  : 4.1.0.dev0.
> Le mer. 11 oct. 2023 à 12:13, Giovanni Allegri <
> giovanni.allegri at geosolutionsgroup.com> a écrit :
>> Are you running a vanilla GeoNode (i.e. not a GeoNode Project)?
>> Can you share the content of the file geonode/__init__.py? It contains
>> the  __version__ variable.
>> Otherwise you con obtain it from the browser:
>> https://yourgeonode.com/version.txt (example
>> <https://development.demo.geonode.org/version.txt>).
>> Giovanni
>> On Wed, Oct 11, 2023 at 10:13 AM Alexandre Gacon <
>> alexandre.gacon at gmail.com> wrote:
>>> Hello,
>>> The requirements file which is embedded in the docker image.
>>> Le mar. 10 oct. 2023 à 17:59, Alexandre Gacon <alexandre.gacon at gmail.com>
>>> a écrit :
>>>> I will get it as soon as possible.
>>>> Le mar. 10 oct. 2023 à 17:58, Giovanni Allegri <
>>>>> Paste here the content of the src/requirements.txt file.
>>>>> Giovanni
>>>>> On Tue, Oct 10, 2023 at 5:54 PM Alexandre Gacon <
>>>>>> Hi Giovanni,
>>>>>> Thanks for the reply. I had a look at the docker compose file for the
>>>>>> version so probably this is not the good place to get it.
>>>>>> What do you suggest to retrieve the correct version?
>>>>>> Regards
>>>>>> Alexandre
>>>>>> Le mar. 10 oct. 2023 à 17:29, Giovanni Allegri <
>>>>>>> This endpoint has been available since version 4.1.0
>>>>>>> <https://github.com/GeoNode/geonode/pull/10941>.
>>>>>>> Giovanni
>>>>>>> On Tue, Oct 10, 2023 at 8:58 AM Alexandre Gacon via geonode-users <
>>>>>>> geonode-users at lists.osgeo.org> wrote:
>>>>>>>> Hello,
>>>>>>>> For a few weeks now, our geonode instance always returns a 404
>>>>>>>> error when we try to use the linked_resources endpoint of the API.
>>>>>>>> As a result:
>>>>>>>> - The map preview in the right side of a dataset is never displayed
>>>>>>>> with an ever lasting loader
>>>>>>>> - When we try to create a new map, we also have an ever lasting
>>>>>>>> loader, we never get to display the default basemap
>>>>>>>> - Existing maps are displayed correctly
>>>>>>>> The problem happens with either layers in database or with new
>>>>>>>> layer uploaded with shapefile.
>>>>>>>> GeoNode version : 4.0
>>>>>>>> GeoServer version : 2.20.6
>>>>>>>> Do you have any idea on what's going on?
>>>>>>>> Alexandre Gacon
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts!
>>>>>>> Visit http://bit.ly/gs-services-us for more information.
>>>>>>> Dott. Giovanni Allegri
>>>>>>> Technical Lead / Project Manager
>>>>>>> GeoSolutions Group
>>>>>>> phone: +39 0584 962313
>>>>>>> cell:     +39 345 2815774
>>>>>>> fax:      +39 0584 1660272
>>>>>>> https://www.geosolutionsgroup.com/
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> GeoSolutions Group
>>> Alexandre Gacon
>> GeoSolutions Group
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> Alexandre Gacon
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20231012/cc08ad2d/attachment-0001.htm>
More information about the geonode-users mailing list
