[Geoprisma-dev] PGSQLMapContextConfig - ticket(s)
Yves Moisan yves.moisan at boreal-is.com
Thu Jul 22 11:06:20 EDT 2010
Le 2010-07-09 09:43, Alexandre Dube a écrit :
> Hi,
>   I am pleased to announce that another step towards a GeoPrisma
> config in a database is now completed.  The ticket [1] contains the
> whole story of the work done so far and what's remaining to do.  I'm
> going to add a final comment describing a summary of the work
> remaining to do.
>   Instead of continuing to update this same ticket (which is becoming
> a bit too big to my taste), I'm proposing to add a final comment
> referring to a buch of other new tickets (to separate the remaining
> tasks to do in multiple tickets).  When all these new tickets would
> all be closed, the main one would be closed.  Here's a list of tickets
> I propose to open (for now) :
>   * documentation of all new resource options (1 ticket)
>   * GUI admin tool to setup the DB config (1 ticket)
>   * support for remaining widgets that are currently unsupported or
> incomplete (missing options for example) in the new config (1 ticket /
> widget)
>   Comments would be welcomed.
Failing more detailed comments from others, I would say it looks good :
go for it.  You're the lead on that !  I'm eager to know what widgets
are or not supported in the new config.
Thanx !
Yves
More information about the Geoprisma-dev mailing list
