[geos-devel] 3.2.0 Final
strk strk at keybit.net
Sat Dec 12 03:37:02 EST 2009
On Fri, Dec 11, 2009 at 03:55:54PM -0500, Frank Warmerdam wrote:
> I am not aware of memory leaks related to the C++ API, and if there are some
> there is no reason not to fix them.
I'm not aware either, but it may happen because the clients
we test GEOS again all use the C Api, which doesn't expose
the leaks itself.
I just fixed a couple of leaks reported by a C++ API user
in methods that would never be called by the C-Api, that's
why I mentioned them.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
