[GRASS-SVN] r45989 - grass-addons/gui/wxpython/wx.psmap/gui_modules
Fri Apr 15 10:42:47 EDT 2011
Author: annakrat
Date: 2011-04-15 07:42:47 -0700 (Fri, 15 Apr 2011)
New Revision: 45989
   grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
wx.psmap: availability of ps2pdf tested earlier
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-15 14:42:30 UTC (rev 45988)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-15 14:42:47 UTC (rev 45989)
@@ -352,6 +352,15 @@
     def OnPDFFile(self, event):
         """!Generate PDF from PS with ps2pdf if available"""
+        try:
+            p = subprocess.Popen(["ps2pdf"], stderr = subprocess.PIPE)
+            p.stderr.close()
+        except OSError:
+            GMessage(parent = self,
+                    message = _("Program ps2pdf is not available. Please install it first to create PDF."))
+            return
         filename = self.getFile(wildcard = "PDF (*.pdf)|*.pdf")
         if filename:
             self.PSFile(filename, pdf = True)
@@ -359,8 +368,6 @@
     def OnPreview(self, event):
         """!Run ps.map and show result"""
         self.PSFile()
     def PSFile(self, filename = None, pdf = False):
         """!Create temporary instructions file and run ps.map with output = filename"""
@@ -418,11 +425,14 @@
         if event.userData['pdfname']:
             try:
-                ret = subprocess.call(['ps2pdf', '-dPDFSETTINGS=/prepress', '-r1200', event.userData['filename'], event.userData['pdfname']])
+                proc = subprocess.Popen(['ps2pdf', '-dPDFSETTINGS=/prepress', '-r1200',
+                                        event.userData['filename'], event.userData['pdfname']])
+                ret = proc.wait()
                 if ret > 0:
                     message = _("ps2pdf exited with return code %s") % ret)
             except OSError, e:
                 GError(parent = self,
                        message = _("Program ps2pdf is not available. Please install it to create PDF.\n\n %s") % e)
