[GRASS5] gis.m as default GUI
Wed Apr 26 15:15:48 EDT 2006
William Kyngesburye wrote:
> That's not what I mean - I know about using GRASS_WISH to set the
> particular wish binary to use, that's how I force GRASS to use my X11
> Tcl/Tk instead of Apple's default.  It's just that when I use the Tk
> Aqua wish, it's a separate Mac OS X application, not run inside of
> X11, and the system just knows it as 'wish' (in the menubar, the
> Dock, and CLI ps command).
> I know in Java applications, there is a way to rename the application
> so it doesn't run as 'Java'.  Is there something similar for wish?
Try "wish -name <name>", or putting "tk appname <name>" at the
beginning of the script.
