[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton michael.barton at asu.edu
Mon Jul 28 16:06:51 EDT 2008
On Jul 28, 2008, at 8:35 AM, William Kyngesburye wrote:
> On Jul 28, 2008, at 9:34 AM, Glynn Clements wrote:
>>> We needed the -framework flags because -l would get the system tcltk
>>> symlinks.
>> Er, not if you also use -L, surely?
> I never got a clarification from Michael (or I missed it) if -L/usr/
> lib was in his link command for NVIZ.  That would have confused the
> linking, if it was before the tcltk -L flag.
I never messed with anything in platform.make except for the TCLTKLIB
section that you mentioned.
Michael
>> Have you actually tried changing the #include directives to e.g.
>> <Tk/tk.h> and using the --framework= option?
>> The first place to try would be togl.[ch] in visualization/nviz/src.
> Yes, that's when I ran into this problem.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
