[GRASS-dev] NVIZ Error: Error of failed request: BadWindow
Fri Mar 18 19:59:53 EDT 2011
peter.loewe at gmx.de wrote:
> I am building GRASS6.4 from source on a computation cluster. GRASS
> itself is up and running, but NVIZ causes trouble:
> When invoking NVIZ from the GRASS command line (nviz -q), the NVIZ
> command window pops up and throws this error message:
> Error of failed request:  BadWindow (invalid Window parameter)
>   Major opcode of failed request:  3 (X_GetWindowAttributes)
>   Resource id in failed request:  0xffffffff
>   Serial number of failed request:  237
>   Current serial number in output stream:  238
Are you using "ssh -X"? Tk needs "ssh -Y" (or ForwardX11Trusted).
Other than that, I have no idea.
