[GRASS-dev] osgeo4w package for GRASS 7
Vaclav Petras wenzeslaus at gmail.com
Sat Feb 21 13:48:51 PST 2015
On Sat, Feb 21, 2015 at 3:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Feb 21, 2015 at 6:17 PM, Martin Landa <landa.martin at gmail.com>
> wrote:
> > to summarize OSGeo4W proposal:
> > * `grass` will be 7.0.0
> > * `grass6` will be 6.4.4 (hopefully soon 6.4.5)
> > * `grass-svn` will be 7.0.1svn (*)
> > * `grass-trunk-svn` will be 7.1svn
> > * `grass64-dev` will be removed
> > Martin
> > (*) `dev` is really misleading here, so `svn` or `daily` (`svn` sounds
> > more technical).
> We should follow somewhat the naming scheme in OSGeo4W. Here what QGIS
> does:
> http://trac.osgeo.org/osgeo4w/wiki/pkg-qgis
> Packages:
> qgis: QGIS Desktop
> qgis-server: QGIS Server
> qgis-common: common dependencies of qgis/qgis-server
> qgis-devel: headers and libraries for development
> qgis-oracle-provider: Oracle provider for qgis/qgis-server
> qgis-grass-plugin: GRASS plugin for qgis
> qgis-globe-plugin: GLOBE plugin for qgis
> qgis-full: (extensive) optional dependencies for qgis
> qgis-dev: Nightly build of master
> qgis-full-dev: (extensive) optional dependencies for qgis-dev
> qgis-dev-pdb: debugging symbols for qgis-dev
> --> They call it -dev, not -svn.
> In fact, they call it -dev not -trunk-svn. The difference is that QGIS
does not have two "development" versions. Perhaps we also don't need a
package for 70 branch (later replaced by 71, 72, ...). Perhaps it is enough
to have packages just trunk and official releases (now 7.0.0 and 6.4.4).
The issue with QGIS naming is that -dev and -devel is complete opposite
meaning the for Debian packaging (devel repository versus dev packages).
Please correct if I'm wrong. But anyway, with -dev and -devel it is hard to
say which one is which if you don't see the description.
For the rest, Martin's suggestion is similar.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150221/3b6de25c/attachment.html>
