[GRASS-dev] GRASS GIS: backport of CI speed updates to G83?
Vaclav Petras wenzeslaus at gmail.com
Thu Feb 22 17:52:01 PST 2024
On Tue, 20 Feb 2024 at 04:14, Markus Neteler via grass-dev <
grass-dev at lists.osgeo.org> wrote:
> In fact the slowest CI run determines how much time I have to wait
> with each release step (i.e., editing VERSION file, wait 1:30hs, do
> some steps, wait 1:30hs, create tarball, wait 1:30hs, reset VERSION
> file, wait 1:30hs ... which is a pain).
Isn't the issue the release procedure itself? It has a bunch of steps which
need to be done manually.
I counted 3 pushes which is what triggers the CI.
1) release VERSION file push
2) tag push
3) development VERSION file push
The release needs step 2 to be completed. We were doing step 2 only after
CI for step 1 completed to make sure the CI runs on the branch at that time
before the tag is made in step 2. I guess the reason to wait after step 2
before doing step 3 is to make sure that the automated part of the release
procedure linked to step 2 actually went through. Is this correct?
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240222/1ae20f75/attachment-0001.htm>
