[STATSGRASS] problem with RdbiPgSQL c.d.
Markus Neteler neteler at itc.it
Wed Aug 30 15:32:03 EDT 2006
On Wed, Aug 30, 2006 at 09:00:16PM +0200, Roger Bivand wrote:
> I would first try to use the versions from
> http://www.bioconductor.org/packages/1.8/bioc/ - I don't know why Markus
> has 1.9, they are for R 2.4, not 2.3, because there is a major
> discontinuity in object defintions between 2.3 and 2.4, which may be being
> picked up when a package prepared for 2.4 tries to read an object saved
> under 2.3.
> Markus - was there a reason for writing 1.9? The change in object
> structure is very recent, and another one happened today - 2.4 is changing
> fast at the moment.
Dear Roger, all,
no particular reason for 1.9. I have changed it to 1.8 now.
In the past I always used the dev version, but according to your
comments that's no longer appropriate.
sorry for any confusion,
Markus
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats mailing list
