[STATSGRASS] rgdal doesn't work with GDAL 1.4.0
jarekj at amu.edu.pl jarekj at amu.edu.pl
Sun Jan 7 14:40:40 EST 2007
Carlos!
I mentioned it two weeks ago!
It it effect of simple configure check test wchich test only if gdal is
of version 1.3.x
to solve it:
download rgdal to local computer,
unpack tar package,
edit cofigure, go to line 1334,
change REQ_GDAL from "1.3" to "1.4"),
pack it again (name must be the same!),
and istall extension with R CMD INSTALL 'rgdalxxxx"
it had help on my computer (btw, on fresh edgy be prepered for some
surprises with nviz)
btw2: rgdal maitainer shall change configure.in file to maintain both
1.3.x and 1.4.x gdal wersion imediatelly
regards
Jarek
7/1/2007, ""Carlos \"Guâno\" Grohmann"
carlos.grohmann at gmail.com"
<"=?ISO-8859-1?Q?Carlos_\"Gu=E2no\"_Grohmann?="
carlos.grohmann at gmail.com> napisał/a:
>Hello all
>I have just made a fresh install, using Ubuntu Feisty for upgrade, so
>now I have GDAL 1.4.0 and R 2.4.1. when I tryed to install rgdal, I
>get this error:
>* Installing *source* package 'rgdal' ...
>gdal-config: gdal-config
>GDAL version 1.4.0 found ...
>For building this version, at least GDAL version 1.3.1 is required.
>ERROR: configuration failed for package 'rgdal'
>** Removing '/usr/local/lib/R/site-library/rgdal'
>I don't get it. If my version is higher than the required one, why it
>doesn't work?
>Carlos
>              Carlos Henrique Grohmann - Guano
>  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
>Linux User #89721  - carlos dot grohmann at gmail dot com
>_________________
>"Good morning, doctors. I have taken the liberty of removing Windows
>95 from my hard drive."
>--The winning entry in a "What were HAL's first words" contest judged
>by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
>_______________________________________________
>statsgrass mailing list
>statsgrass at grass.itc.it
>http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
