[STATSGRASS] rgdal doesn't work with GDAL 1.4.0
Roger Bivand Roger.Bivand at nhh.no
Sun Jan 7 15:25:31 EST 2007
On Sun, 7 Jan 2007 jarekj at amu.edu.pl wrote:
> Carlos!
> I mentioned it two weeks ago!
GDAL 1.4.0 was released 6 January 2007 13:10:21 -0500, so early evening
CET yesterday. No mention reached me (please do write directly to the
package maintainer in such cases, mailing lists can be subject to
back-ups). rgdal has tracked GDAL cvs, and I am now looking at the issue,
which I do not consider critical - anyone wanting to be on the bleeding
edge has to be prepared to handle these slippages from time to time.
If you have a working patch (that works for both 1.3.* and 1.4.0), I would
be grateful. What you propose below is not acceptable, because both have
to be accommodated.
Roger
> It it effect of simple configure check test wchich test only if gdal is
> of version 1.3.x
> to solve it:
> download rgdal to local computer,
> unpack tar package,
> edit cofigure, go to line 1334,
> change REQ_GDAL from "1.3" to "1.4"),
> pack it again (name must be the same!),
> and istall extension with R CMD INSTALL 'rgdalxxxx"
> it had help on my computer (btw, on fresh edgy be prepered for some
> surprises with nviz)
> btw2: rgdal maitainer shall change configure.in file to maintain both
> 1.3.x and 1.4.x gdal wersion imediatelly
> regards
> Jarek
> 7/1/2007, ""Carlos \"Guâno\" Grohmann"
> carlos.grohmann at gmail.com"
> <"=?ISO-8859-1?Q?Carlos_\"Gu=E2no\"_Grohmann?="
> carlos.grohmann at gmail.com> napisa³/a:
> >Hello all
> >I have just made a fresh install, using Ubuntu Feisty for upgrade, so
> >now I have GDAL 1.4.0 and R 2.4.1. when I tryed to install rgdal, I
> >get this error:
> >* Installing *source* package 'rgdal' ...
> >gdal-config: gdal-config
> >GDAL version 1.4.0 found ...
> >For building this version, at least GDAL version 1.3.1 is required.
> >ERROR: configuration failed for package 'rgdal'
> >** Removing '/usr/local/lib/R/site-library/rgdal'
> >I don't get it. If my version is higher than the required one, why it
> >doesn't work?
> >Carlos
> >              Carlos Henrique Grohmann - Guano
> >  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> >Linux User #89721  - carlos dot grohmann at gmail dot com
> >_________________
> >"Good morning, doctors. I have taken the liberty of removing Windows
> >95 from my hard drive."
> >--The winning entry in a "What were HAL's first words" contest judged
> >by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> >_______________________________________________
> >statsgrass mailing list
> >statsgrass at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
