[STATSGRASS] gstat probability maps
Edzer J. Pebesma e.pebesma at geo.uu.nl
Tue Mar 27 13:34:49 EDT 2007
Dear Wolf & Pierluigi,
I believe that it is another common misunderstanding to believe that
indicator kriging is needed to obtain (estimates of) probabilities. You
can of course do it, try something along the lines of
v <- variogram(I(zinc>500)~1, meuse)
m <- vgm(.15, "Sph", 874, .1) # just filling in some values here
ik <- krige(I(zinc>500)~1, meuse, meuse.grid, m)
but then you give up any information on how far an observation is below
or above 500, as data are transformed to 0 (below 500) and 1 (above 500)
values. IMO this is valuable information, and although you may criticize
the Gaussian assumption (on the log-scale) underlying my previous
suggestion, at least it leads to "true" probabilities, instead of
interpolated 0 and 1 values that may (and will) as well lie outside the
interval [0,1].
I wouldn't go as far as advising never to use indicator kriging, but the
automatic "for probabilities you need indicator kriging" clearly misses
important essentials of geostatistics.
Both issues, the need to simulate or the need for indicator transforms
to obtain probabilities, have been pushed by certain authors that know
better, and re-arise from time to time. A third and related issue is the
suggestion that the (ordinary) kriging variance is not a measure for
prediction error; see the following ai-geostats thread:
http://www.mail-archive.com/ai-geostats%40jrc.it/msg02890.html
Best wishes,
Edzer
Wolf Bergenheim wrote:
> Pierluigi,
> That would be indicator kriging:
> I use gstat, so I can't give you any specific R commands, but the
> principle is the same: You have to create a new dataset which is 1 if
> the threshold is exceeded, and 0 if not. Now your data is 0 or 1. Then
> do normal ordinary kriging on that new data column. The resulting map
> shows the probability of exceeding the threshold. In gstat you have to
> add  extra checks to see that your result is strictly [0.0 - 1.0]
> --Wolf
> On 27.03.2007 18:18, Pierluigi De Rosa wrote:
>> Dear All,
>> I need to prepare a probability map of exceeding a value...
>> I can make the simulation, for example I tried to make it with data meuse:
>> v <- variogram(log(zinc)~1,loc= meuse)
>> m <- vgm(.59, "Sph", 874, .04)
>> sim <- krige(formula = log(zinc)~1, locations = meuse, model = m, newdata =
>> meuse.grid, nmax = 15, nsim = 5)
>> names(sim)
>> [1] "sim1" "sim2" "sim3" "sim4" "sim5"
>> Now How can I create a probabilility map of exceding a value (for example 5)??
>> Thanks
>> Pierluigi
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20070327/ae314308/attachment.html
More information about the grass-stats mailing list
