[GRASS-stats] gstat error
Jarek Jasiewicz jarekj at amu.edu.pl
Sun Apr 26 03:22:40 EDT 2009
Edzer Pebesma pisze:
> Jarek Jasiewicz wrote:
>> Hi
>> during trend calculation I recive following error:
>> R
>> library(spgrass6)
>> library(gstat)
>> raster=readRAST6("rzedna")
>> p=readVECT6("punkty")
>> p at proj4string=raster at proj4string
>> pg_1=gstat(id="p_1", formula=rzedna~1,data=p, degree=1)
>> p_1=predict(pg_1,raster)
>> [ordinary or weighted least squares prediction]
>> "solve.c", line 87: singular matrix in function Usolve()
>> Error in predict.gstat(pg_1, raster) : Usolve
> There are several situations why this can happen that are hard to
> distinguish from the point where the error happens. The most likely in
> your case (first order trend surface estimation) is that your data are,
> geographically, on a line, i.e. one-dimensionally. Or similary, that you
> have less than 3 observations. Is that the case?
> Edzer
Thanks for answer,  but none of that case. Tt is regular data file with
200 random observations generated with v.random in GRASS and stored as
SpatialPointDataFrame.
before I  posted to the list  I had tried to reproduce it on my archive
data with archive scripts (which worked  in older R compilation) and it
ALWAYS fail (on every data I tested).
In general, the possible problem on my side coud be that I
(experientally) installed R from CRAN ubuntu repository instead to
compile from source. The ubuntu CRAN-R packages do not include lapack.
This is the only difference I noticed.
If you need I can send you sample R file (is small, no more than 2MB)
Jarek
>> my system information:
>> Ubuntu 8.04
>> R 2.8.1
>> gstat 0.9.59
>> the error have appeared first time on gstat 0.9.49
>> Errors apears on all my data, even these, where trend was calculated
>> some times ago. Commads coming from old data
>> The error is also reproducible on spearfish dataset with elevation.dem
>> and random points generated by v.random
>> Jarek
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
