[GRASS-stats] "g.region: command not found" using readRAST6 command
Hamish hamish_b at yahoo.com
Wed Oct 7 22:21:12 EDT 2009
Agustin wrote:
> Do the following:
> 1. Locate  your grass.conf file (mine is under /etc/ld.so.conf.d)
> 2. Change
> /usr/lib/grass/lib
> to
> /usr/lib/grass64/lib
> (check where the lib directory of your grass is, mine is
> under /usr/lib/grass64)
> 3. run
> sudo ldconfig
> 4. gmeta() should work now.
> I tried to get the ubuntugis packagers to fix this, but apparently
> nobody cares. See:
> http://n2.nabble.com/Fwd-Re-R-sig-Geo-Errror-with-gmeta6-tp3610348p3610348.html
> for more info.
in the DebianGIS package the lib dir was renamed in 6.4.0~rc3-3 back in
late March. AFAIK UbuntuGIS often just rebuilds the Debian package for
their world.
http://packages.debian.org/changelogs/pool/main/g/grass/grass_6.4.0~rc5-3/changelog
are you using a newer version of grass than rc3?
it looks like Karmic's package has the versioned dirs:
  http://packages.ubuntu.com/karmic/i386/grass/filelist
(rc5-1 is buggy and should not ship without the patch from Debian's rc5-2!!
but that is another matter..
 https://bugs.launchpad.net/ubuntu/+source/grass/+bug/435177
Hamish
More information about the grass-stats mailing list
