[GRASS-stats] "g.region: command not found" using readRAST6 command
Tim Holland timothyholland at gmail.com
Thu Oct 8 00:03:32 EDT 2009
Dear all,
Thank you very much for the help.  In the end, my problem was more basic
than Augustin's suggestion.  Starting R from within GRASS was basically all
I needed to do.  Also, Roger, thank you for the 'pre-emptive' help with your
comment about setting 'plugin=FALSE': sure enough, when I tried without that
command, I got the following and R exited:
> x<-readRAST6("GLC2000_Landcover_SEAsia")
ERROR: Incompatible library version for module. You need to rebuild GRASS
       or untangle multiple installations.
But it worked fine with plugin=FALSE.
Best,
Tim
On Thu, Oct 8, 2009 at 9:21 AM, Hamish <hamish_b at yahoo.com> wrote:
> Agustin wrote:
> > Do the following:
> > 1. Locate  your grass.conf file (mine is under /etc/ld.so.conf.d)
> > 2. Change
> > /usr/lib/grass/lib
> > to
> > /usr/lib/grass64/lib
> > (check where the lib directory of your grass is, mine is
> > under /usr/lib/grass64)
> > 3. run
> > sudo ldconfig
> > 4. gmeta() should work now.
> > I tried to get the ubuntugis packagers to fix this, but apparently
> > nobody cares. See:
> http://n2.nabble.com/Fwd-Re-R-sig-Geo-Errror-with-gmeta6-tp3610348p3610348.html
> > for more info.
> in the DebianGIS package the lib dir was renamed in 6.4.0~rc3-3 back in
> late March. AFAIK UbuntuGIS often just rebuilds the Debian package for
> their world.
> http://packages.debian.org/changelogs/pool/main/g/grass/grass_6.4.0~rc5-3/changelog<http://packages.debian.org/changelogs/pool/main/g/grass/grass_6.4.0%7Erc5-3/changelog>
> are you using a newer version of grass than rc3?
> it looks like Karmic's package has the versioned dirs:
>  http://packages.ubuntu.com/karmic/i386/grass/filelist
> (rc5-1 is buggy and should not ship without the patch from Debian's rc5-2!!
> but that is another matter..
>  https://bugs.launchpad.net/ubuntu/+source/grass/+bug/435177
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20091008/b8df33da/attachment.html
More information about the grass-stats mailing list
