[GRASS-stats] GRASS can't find R packages from personal library on Windows
Markus Neteler neteler at osgeo.org
Thu Nov 24 01:34:45 PST 2016
On Wed, Nov 23, 2016 at 10:56 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> New Revision: 69883
> Modified:
>    grass/trunk/mswindows/env.bat
> Log:
> set R_USER if %USERPROFILE%\Documents\R\ exists to catch most common cases
> of private R libraries in windows
> it should catch at least the common cases where personal libraries are
> located in %USERPROFILE%\Documents\R\
> please test the next standalone winGRASS7.3.svn daily builds
> (https://wingrass.fsv.cvut.cz/grass73/x86_64/ or
> https://wingrass.fsv.cvut.cz/grass73/x86/).
The new installer is available now:
https://wingrass.fsv.cvut.cz/grass73/x86_64/WinGRASS-7.3.svn-r69883-73-Setup-x86_64.exe
(or later)
> if it works, it should be backported to the standalone winGRASS7.0.x and the
> upcoming winGRASS7.2.
If possible, please timely test. I am holding RC2 for this at time.
thanks
Markus
More information about the grass-stats mailing list
