some problems with TclTKGRASS 2.3 release
Der-Johng Sun djsun at gate.sinica.edu.tw
Thu Jul 30 18:51:06 EDT 1998
Antonio Rodriguez Verdugo wrote:
> #loading...
> Application initialization failed:$msg
> Error in startup script: syntax error in expression
> "$database != "" && $location != "" && $mapset != "" "
>         ("if" test expression)
>         while compiling
> "if {$database != && $location != "" && $mapset != ""} {..."
>         ("if" then script line 20)
>         while compiling
> "if {[file exists $filename]} {..."
>         (compiling body of proc "searchGISRC, line 11)
>         invoked from within
> "serachGISRC $gisrc_name"
>         (file "/home/toni/grass/tcltkgrass/main/gis_set.tcl" line 365)
> /usr/local/bin/tcltkgrass:GISDBASE:parameter null or not set
This from Install Text:   If you have to store GRASS in a different
directory (not recommended)
   you have to correct the paths in
or  try   ln -s  /home/toni/grass  /usr/local/grass42
Der-Johng Sun
E-mail: djsun at gate.sinica.edu.tw
