[GRASS-user] v.surf.rst and null values
Dylan Beaudette dylan.beaudette at gmail.com
Mon Mar 3 12:57:50 EST 2008
On Monday 03 March 2008, jessica.gervais at tudor.lu wrote:
> Dear all,
> I have a set of data points in a semi-column separated file(example file :
> test.txt)
> For each location, I have meteo data have been recorded.
> Missing values are represented by represented by blank.
> I am using v.in.ascii to import these points.
> Then, I want to interpolate these point data with v.surf.rst.
> The interpolation should use only points where there data was recorded,
> e.g. to skip points were there is missing value.
> But v.surf.rst threat the missing values as is they were "0".
> Do anyone know how to specify to the v.surf.rst function that blank values
> are null values ?
> Or maybe I should define these point as null values when I import the
> points with v.in.ascii ?
> Many thanks in advance,
> Jessica
> Thanks in advance
The trick is to get v.in.ascii to respect any NODATA conventions that are used
in your input file.
attached is a simple file that contains a NODATA entry, and is read correctly
by v.in.ascii.
Optionally, you can use the 'where' operator for v.surf.rst to pre-filter your
points.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
594342.09375|4922184.3125|5
600721.546875|4918831.390625|2
602650.21875|4923104.140625|
598199.4375|4923015.125|6
