[GRASS-user] movement direction surface in r.drain
Mohammed Rashad mohammedrashadkm at gmail.com
Mon Dec 24 05:54:24 PST 2012
Hi All,
Added the patch please test it and let me know. r.drain(drain.c) now uses
gmath lib for storing elevation data as matrix.
Also a problem i found is outmap is always of type CELL
Will these be a problem?
[0] http://trac.osgeo.org/grass/attachment/ticket/1840/r.drain.diff
[1] http://trac.osgeo.org/grass/attachment/ticket/1840/drain.c
On Sun, Dec 23, 2012 at 11:51 PM, Mohammed Rashad <
mohammedrashadkm at gmail.com> wrote:
> On Sun, Dec 23, 2012 at 10:54 PM, Markus Neteler <neteler at osgeo.org>wrote:
>> On Sat, Dec 22, 2012 at 10:30 PM, Mohammed Rashad
>> <mohammedrashadkm at gmail.com> wrote:
>> > Hi,
>> > I made some modifications to the r.drain code (direction part) which
>> gave me
>> > the following output?
>> > Is this correct?. If so I can finish polishing it ;)
>> > Please see the attachments in the ticket[0]
>> > [0] http://trac.osgeo.org/grass/ticket/1840
>> > input
>> > http://trac.osgeo.org/grass/attachment/ticket/1840/d.rast.num_input.png
>> > output
>> > http://trac.osgeo.org/grass/attachment/ticket/1840/d.rast.output.png
>> http://trac.osgeo.org/grass/attachment/ticket/1840/d.rast.rum.output.png
>> Nice, this looks now pretty similar to
>> http://grass.osgeo.org/grass64/manuals/r.drain.html
>> Please upload the diff then, thanks!
>> Unrelated: I wonder about the shift of grid and pixels in the wxGUI,
>> shouldn't
>> they overlap?
> Yes, you are right. There is a shit. I was trying something and that
> output came up yesterday. Just now I completed r.drain and output looks
> pretty good.
> r.drain direction map generation code is completely wrong Or is not
> working for a long period when I checked trac last update was 3 years ago
> for filldir.c which i guess is incomplete
> *Anyone got good output recently with r.drain?*
> If so please let me know the revision.
> @Markus
> Can I continue fixing r.drain?
> Because currently its works for -c flag which is by default?
> please see new screenshot [0]
> @Margherita Di Leo
> Could you provide your data for testing r.drain module directon
> calculation feeding points from vector?
> [0] http://lsi.iiit.ac.in/new_r.drain_output.png
>> Markus
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121224/1a9a40e3/attachment.html>
