[winGRASS] Installing wingrass and problems with tcltkgrass
Mike Thomas miketh at brisbane.paradigmgeo.com
Tue Jun 3 20:09:01 EDT 2003
Hi Alberto.
This problem seems to be caused by the ongoing trouble with monitors not
being selected immediately after starting them, that is, at the command line
you would have to go
  d.mon start=x0
  d.mon select=x0
rather than:
  d.mon x0
Try launching the monitor from the tcltkgrass Display Manager dialog
launched from menu item:
  Display/Monitors/Manage Display Monitors.
Let us know how that goes for you whether it fixes the problem for you or
not.
Cheers
Mike Thomas.
| -----Original Message-----
| From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
| Behalf Of Alberto Sánchez
| Sent: Tuesday, June 03, 2003 7:44 PM
| To: Wingrass
| Subject: [winGRASS] Installing wingrass and problems with tcltkgrass
| Hello to all:
| I have installed wingrass 5.0.2 on WinXP through the binary files
| and I have
| problems with the monitors when I use tcltkgrass (When I open a
| monitor from
| menu of tlctkgrass, this monitor immediately closes after being opened).
| Could It be better to compile all wingrass instead of installing
| it through
| the binary files to avoid this problem?
| Thanks!
| ALBERTO SÁNCHEZ GÓMEZ
| Centro de Estudios Hidrográficos del CEDEX
| Paseo Bajo de la Virgen del Puerto, 3
| 28005 Madrid, España
| _______________________________________________
| winGRASS mailing list
| winGRASS at grass.itc.it
| http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
