[winGRASS] grass on cygwin first run
Glynn Clements glynn.clements at virgin.net
Mon Jan 12 02:31:06 EST 2004
Richard Greenwood wrote:
> As always - thank you for your untiring willingness to field these
> questions. I just build 5.0.3 on Cygwin (verifying that only the 8.3
> xtcltk was installed). The tcltkgrass menus appear to work, but
> unfortunately, on launching NVIZ, I get the following error almost
> immediately:
> child killed: segmentation violation
To get anywhere with this, you will have to run NVIZ under a debugger,
e.g.
	$ gdb /usr/local/grass5/etc/nviz2.2/NVWISH2.2
	> run -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script dem_bulter_creek8ft vect=road_cl -name NVIZ
	[gdb reports "Segmentation fault."]
	> where
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
