[winGRASS] Re: help with wingrass initialization
Jeinith García Vera jeinith at hotmail.com
Mon Nov 27 13:11:08 EST 2006
Hola!!!
Jeremy, did you change the grass.bat file before (in ...msys\1.0\)?
set STARTUP_DIR=C:\msys\1.0
set PATH=%PATH%;C:\Archivos de
programa\PostgreSQL\8.1\bin;C:\MinGW\mingw\bin
set GRASS=grass
set GRASS_WISH=wish84.exe
and some line down there:
rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
rem to represent.
Another thing, when you saved the spearfish sample file the "permanent" and
"user1" files comes inside that file, you dont have to create them...
ok, keep speaking to you from the office, I haven't installed here the
spearfish sample..
Tell me if you resolve anything...
_________________________________________________________________
Acepta el reto MSN Premium: Protección para tus hijos en internet.
Descárgalo y pruébalo 2 meses gratis.
http://join.msn.com?XAPID=1697&DI=1055&HL=Footer_mailsenviados_proteccioninfantil
More information about the grass-windows mailing list
