[winGRASS] thanks in advance......
Sat Feb 17 16:12:28 EST 2007
sijan ahamed wrote:
> I think it is due to problem with tcl/tk.
> I was using packages (gcc,zlib,..) installed along with cygwin...except gdal
> and proj which i compiled&installed from source code..
There is a Cygwin package for the PROJ library; it isn't necessary to
compile that yourself.
More information about the grass-windows mailing list
