[GRASS-windows] Colour code vector maps
Arran_Jay james.mccairns at openreach.co.uk
Thu Aug 14 05:21:32 EDT 2008
>How did you launch d.vect.thematic. AFAIR, d.vect.thematic should work
>in the GUI, i.e. using the 'Add thematic layer' button. If you want to
>call d.vect.thematic from a command line, use the -s flag, so that it
>doesn't use monitors.
>If you don't get a nice legend in the GUI, you can use the psmap=
>parameter to create a ps.map instruction files, one for the map and one
>for the legend
When I try and add a vector layer through the GUI I get the error message:
dirname: extra operand `and'
Try `dirname --help' for more information.
cp: target `/gismlegend.txt' is not a directory
rm: cannot remove directory `d:/documents': Is a directory
Then the monitor loads up a blank screen and I get a blank legend box.
View this message in context: http://www.nabble.com/Colour-code-vector-maps-tp18958807p18978349.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
