[GRASS-windows] Colour code vector maps
Thu Aug 14 09:23:19 EDT 2008
Arran_Jay wrote:
> >How did you launch d.vect.thematic. AFAIR, d.vect.thematic should work
> >in the GUI, i.e. using the 'Add thematic layer' button. If you want to
> >call d.vect.thematic from a command line, use the -s flag, so that it
> >doesn't use monitors.
> >If you don't get a nice legend in the GUI, you can use the psmap=
> >parameter to create a ps.map instruction files, one for the map and one
> >for the legend
> When I try and add a vector layer through the GUI I get the error message:
> dirname: extra operand `and'
> Try `dirname --help' for more information.
> cp: target `/gismlegend.txt' is not a directory
> rm: cannot remove directory `d:/documents': Is a directory
This appears to have been fixed in r30548; you can obtain the updated
version of the script from:
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/d.vect.thematic/d.vect.thematic
More information about the grass-windows mailing list
